Philips Pronto Pro -- Import -- ?
Gliese 581c
I live in the UK and want to buy the Pronto Pro remote. Cheapest Ive seen it in the UK is for £600.
I see they are around $480-$550 in the US and would like to try and save cash on this, so I would like to buy from the US.
Would buying a pronto pro from the US be ok ? Everything would work the same and I would have no troubles, would I ? Compatibility etc etc (I know I would need a stepdown transformer)
Basically what I want to know if there are any pitfalls I should know about.. ?
homethx
You can get them from richer sounds for £5oo on line or in the shop if you tell them the on line price . everything will work the same just the charger is the problem and the RF as it's not legal in this country and you have to use the us ccf software.
buns
RF is not legal??? :confused:
and surely the US software is the same as the UK!?
ad
homethx
sorry you can use the software you just have to select the right model when it start up pronto edit . if you use the RF base station you can not use it in this country as that frequency is used for something else ? we use 433mhz usa use 418mhz .
Gliese 581c
what exactly does that mean ?
I shouldnt buy it ? or ?
From Richer sounds = £500
From the US = £375 delivered
Theres a big price difference right there. But I dont want to waste money.
Thanks again
Gliese 581c
Ahhh, so the RF unit is the little addon that lets you use the remote in another setup in another room ?
If it is, I dont need that RF unit. I just want the remote and the docking station...... ok to buy it now ?
homethx
read this on what i mean. buy it from the usa if only going to use IR only, watch out for import tax.
homethx
yes it will
