Philips Pronto & Philips 963SA DVD Player
Discussion in 'Home Cinema Control & Remote Controls' started by MontyUK, Jan 15, 2003.
  1. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    Hi all,
    Got my new pronto last night, and have a 963SA on order from unbeatable. My question is, does anyone know of a CCF file for the 963SA yet, or alternatively know whether any of the other Philips DVD Player CCF's will work with the 963 ?
    I've had a search in the files section on remotecentral.com, but there doesn't seem to be any mention of the 963 on there yet.
    Thanks in advance,
  2. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    if you can't find one on remote central, then there probably isn't one at the moment.
    However, most CCF's for Philips DVD players should work in some way, as they will all use Philips RC5 codes. Even if they don't then you can use one that looks good as the basis for yours and learn the codes from the original remote.
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    shame that there isn't one yet.
    My DVD player page mostly references a hidden page with the controls on it. So I should just be able to relearn those main buttons and any references will be handled automatically. Probably the most efficient way to do it.
    If you already have a DVD player CCF, you could just relearn the DVD buttons when you get your 963. Only take a few minutes in front of your PC.
  4. MontyUK
    MontyUK
    Dec 6, 2002
    158
    16
    Yorkshire
    Thanks for the responses guys . . . I'll take a look when my 963SA arrives.
