Philips Pronto Neo???
Discussion in 'Home Cinema Control & Remote Controls' started by kraal, Jan 7, 2005.
  1. kraal
    kraal
    Aug 23, 2004
    96
    Portugal
    Hi ppl,
    Any one use this remote and/or have the IRCodes for Tag processors (AV30R in this case). I think the codes are equal for all AV3xR, as the control chip is the same. In better case the .ncf files.
    Thanks,
  2. kraal
    kraal
    Aug 23, 2004
    96
    Portugal
    And for Denon DVD2200?
    Thanks,
  3. mambojambo
    mambojambo
    Dec 23, 2004
    141
    +3
    they are available onHERE for the pronto pro if you want to try the neohacker route :smashin:
  4. dambox
    dambox
  5. kraal
    kraal
    Aug 23, 2004
    96
    Portugal
    No, I talking about AV30R.
    Thanks guys,
  6. PMM
    PMM
    Do you know how to program the codes for the neo? If you don't I suggest you download the marantz 3200 software. While you can't directly program your neo with this software you can enter the pronto codes which everybody seems to have into the 3200 software. Once you programmed the codes you can now look at them through neohacker. This will allow you to enter the neo codes(equivalent to 3200 codes) once again using neohacker. Good luck
  7. kraal
    kraal
    Aug 23, 2004
    96
    Portugal
    Thanks, :smashin:
