Philips Pronto Neo???
Discussion in 'TAG McLaren Audio Owners' Forum' started by kraal, Jan 7, 2005.
  1. kraal
    kraal
    Aug 23, 2004
    96
    Portugal
    Hi ppl,
    Any one use this remote and/or have the IRCodes for Tag processors (AV30R in this case). I think the codes are equal for all AV3xR, as the control chip is the same. In better case the .ncf files.
    Thanks,
  2. PhilB1234
    PhilB1234
  3. kraal
    kraal
    Aug 23, 2004
    96
    Portugal
    Dear Phil,
    The NEO software don't open the CCF files, it only work with .NCF ones.
    But if you have the IRcodes, it will be good.
    Meanwhile I will make it by hand.
    Thanks,
  4. Teejoo
    Teejoo
    Apr 24, 2004
    221
    The Netherlands
    +3
    Here's a list with the codes the AV32R DP understands, so I guess the basic ones will do for the AV30R.
  5. kraal
    kraal
    Aug 23, 2004
    96
    Portugal
    I will try it.
    Thanks,
  6. PMM
    PMM
    Check out my reply in your other thread. You might find it helpful.
  7. kraal
    kraal
    Aug 23, 2004
    96
    Portugal
    Thanks, :smashin:
