philips pronto 940 v marantz rc5000i
Discussion in 'Home Cinema Control & Remote Controls' started by G.M, May 20, 2002.
  1. G.M
    G.M
    Price for the philips at Richer sounds including docking station is
    £185. Price of the Marantz at another dealer is £330.
    Apart from the Pc cable and I think you also get a CD rom with
    the Marantz, what are the differences between the two?
    I downloaded the technical specs. on both models from the
    Marantz and Philips websites they appear identical. Am I missing
    something obvious, as there's a big price differential?
    I assume you can buy the PC cable and CD Rom for the Philips?
    regards,
    G.M.
  2. mjn
    mjn
    May 24, 2001
    21,424
    Herts, England
    +8,981
    both are the same unit.
    Except the pronto has a few inbuilt codes, you also get the PC-cable with the pronto, but you have to download the software.
    I also think the RC5000i, has a couple of different functions on the "hard-buttons"
    goto www.remotecentral.com for a comparison
  3. G.M
    G.M
    mjn,thanks for the link.Looks like I'll be buying the Philips.
    Apart from having a warranty that's two years longer the Marantz
    doesn't offer anything extra. In fact, it misses out on one of the main features I was looking for, a built in timer.
    Even if I was paying the full price of £250+£50 for the docking station it's still £30 cheaper than the Marantz, can't understand
    Marantz's logic.
    Is the docking station still available from Richer sounds, had a
    look at another thread and it said some stations had a problem with pins melting?
    regards,
    G.M.
  4. Doubledoom
    Doubledoom
    That is very expensive for the RC5000i. The gap is normally only slightly more expensive for the marrantz.
    Personally, i went for the marrantz as i wanted the jump to option and the control of the back/forward buttons.
  5. Cool-hand
    Cool-hand
    Jan 5, 2002
    2,105
    Portsmouth / Middle East
    +77
    Hows the jump to feature work, I mean in what senario do you use it? Also the control of the forward/backward buttons?
    Im in the market still for a remote, bought the rc1200 today for 30 squid cause I cant make my mind up which remote to get so this is a stop gap!
  6. mjn
    mjn
    May 24, 2001
    21,424
    Herts, England
    +8,981
    i got the docking station for £30 at Richer Sounds.
  7. G.M
    G.M
    'Phoned Philips today, woman I spoke to admitted they'd had a problem with some docking stations melting pins, put it down to a faulty batch. Richer sounds have sold out of the docking station hoping to get more in shortly.
    regards,
    G.M.
  8. LDR
    LDR
    Apr 1, 2002
    2,301
    Wales
    +101
    If your struggling to get a docking station then try www.letsautomate.com ..very good service from them...
