Philips Plasma Vs LG LCD
Discussion in 'LG TVs Forum' started by michaelscullion, Sep 11, 2007.
  1. michaelscullion
    michaelscullion
    Hi...
    Looking for some help on a matter...any advice will be much appreciated.
    I have a choice of 2 TV's...
    Philips 42' Plasma PFP5532
    spec...................... http://www.zettavolt.co.uk/HDTV/42PFP5532.html
    LG 42' LCD 42LC55
    spec.......................http://www.zettavolt.co.uk/HDTV/42LC55.html
    It's definitely between one of these two so not looking for other suggestions (or my head will be pickled any further)...I'm getting them on a deal so that;s why it's one or the other.
    I'll be using them for Digital Freeview TV, XBox 360, and DVD player...and maybe eventually HD-DVD.
    Thanks in advance for any opinions.
  2. choddo2006
    choddo2006
    Dec 30, 2005
    8,528
    +542
    There's a thread about the Philips if you have a quick search, lots of owner opinions in there that should help. I would imagine there's an equivalent about the LG in the LCD forum.
  3. michaelscullion
    michaelscullion
    Yeah, I've read the other thread...
    I;ve read loads of threads and reviews about both and I'm still no closer to a decision.
    My main worries are: the XBOX360 - will it look much better on the LCD as it has a slightly higher resolution?
    :digital freeview viewing - will this look much better on the PLasma?
    are plasma's really prone to problems?
    thanks again
