Philips plasma or NTL problem
Discussion in 'Cable TV & Virgin Media TV' started by johnny boy, May 25, 2004.
  1. johnny boy
    johnny boy
    arial
    Just bought philips 37pf9965 linking with ntl digital,dvd and vhs, Picture is far from perfect(great on DVD), does anyone know if this is an NTL problem
  2. jmack
    jmack
    make sure the ntl box is set to RGB not pal/composite
  3. gingerone
    gingerone
    Dec 10, 2002
    2,567
    +388
    Picture with my ntl is fantastic.
  4. johnny boy
    johnny boy
    Is there a switch setting on ntl box for RGB?
    Any other philips 37pf9965 owners experienced any picture problems?
  5. jmack
    jmack
    if i remember right, its in the services menu
  6. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Make sure NTL is plugged into one of the two RGB compatible scarts...
    (and that you are using fully wired scart leads)
  7. gingerone
    gingerone
    Dec 10, 2002
    2,567
    +388
    go to guide and then settings and then visual settings.
