Philips Plasma 37PF9965
Discussion in 'Philips TVs Forum' started by SteveMark, Feb 2, 2009.
  1. SteveMark
    SteveMark
    Feb 2, 2009
    Hello, Need some advice from someone in the know about a problem with the multi-media box FT9965 that comes with this model.
    Had this problem before and had it fixed, apparently they had to replace the CP MP40 they said this is a fuse on a cuiruit board ?
    Since the repair 2 years ago the plasma and box has worked perfectly until the set was turned off at the mains plug a few times which is exactly what happened last time, usually the set is left with power on in standby mode.
    Explained the problem to Philips who contributed to the repair last time but this time don't want to know.
    This must be a fault that has been there since the day of purchase.
    Can I fix this problem myself where is the part located ? :lease:
