Philips PF9986 series- HDCP compliant?
Discussion in 'Philips TVs Forum' started by Toine, Oct 1, 2004.
Tags:
  1. Toine
    Toine
    Hi there,
    Anybody here knows if the pf9986 series is hdcp compliant?
    Before i buy, i would like to know if i can connect a dvd player with DVI-D with this TV?
    Thank you.
    Toine
  2. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Yes, it is HDCP compliant and should play from a HDCP DVD player via HDMI/DVI-D. However, I would recommend trying the player/screen combination with a non copy protected disc to ensure that:
    1. It will display something despite HDCP.
    2. It will display as you expect rather than some defaulting to a non optimal resolution. The EDID data returned by these displays is often wrong which may result in some players choosing a different resolution than that desired.
    -Ian
  3. Toine
    Toine
    Ian,
    Thanks.
    Regards,
    Toine
