Philips PF9986 DVI Connection
Discussion in 'LCD & LED LCD TVs' started by jimsan, Dec 11, 2004.
  1. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Hi. Just hooking up my new Philips 32" PF9986 LCD TV. (The Ambilight one). I would like to run my DVD player using Component connections and Progressive Scan.
    The set doesn't have traditional Component connections, but a weird DVI/Component adaptor thing. However, the cables are RCA colours and not component colours.
    Questions are:
    Is this really a component connection?
    Which colours go with which?
    On another tack, the assembly instructions for the base have a weird graphic at the end with a picture of the set with some direction arrows with a big 'X' through it and a Clock with 72H beside it?????? I hope this doesn't mean you've not to move the set for 72 hours before turning it on!
    Sorry this is such a long story, but your help would be much appreciated.
    Jimmy
  2. exciton
    exciton
    May 8, 2004
    9
    immy,
    The DVI connection is a continual debate. Have a good read through the thread oiginally started by chunkymunky http://www.avforums.com/forums/showthread.php?t=155286
    I just assumed the wierd graphic was not to move the set until the glue on the feet had set!
    Mark
  3. Alan D
    Alan D
    The specific piece of info you need (this originates from Philips apparently) is:
    Red is connected to Red
    Yellow is connected to Blue
    White is connected to Green
  4. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    Check back to the thread mentioned above. I have managed to suss the DVI thing and have given details about how to get it working there.
    Thanks for the replies.
    Jimmy
