Philips or Sony
B
BBlue
what would you pick???
i'm deciding between the Philips Garbo Matchline
500:1, 1100 ansi, 854*... XGA, 2 y warrenty
or the Sony HS2
600:1, 1000 ansi, 854*... WGA, 1y warrenty
sony is about 100pounds cheaper
but the philips has a lamplife of 6000hours instead of sony's 2000
i'm a complete novice
JonMace
Have not seen either demoed but as to price and lamp life it deppends on what you are going to use it for, if it will be for a couple off dvds each week it will probably not make too much difference, if on the otherhand you will watch every thing through it sky etc the the triple lamp life will be very worth while
B
BBlue
It's gonna be used for a few movies a week (almost every day)
and for watching TV thru it
JonMace
I brought my Sony HS1 in March up to 1700 hrs on the lamp now so reccon that about 12 months to a lamp is what I'll get and a replacement lamp is £300, there fore triple lamp hrs is well worth while
Podcast: LCD TVs for Movies, Laser Projectors, RIP Ennio Morricone, AV & Movie news, B+W Matt Damon
