Philips or Sharp
Discussion in 'Philips TVs Forum' started by viewer, Oct 14, 2004.
Tags:
  1. viewer
    viewer
    Sep 26, 2004
    91
    See that the Philips 37pf9986 beat the Sharp 37GD1 - see the latest edition of Home Cinema Choice . Been jumping betwen these 2 options for a while now and still can't make my mind up. Sharps looks better than the philips, concerned about the number of comments appearing about sharp picture quality. Sharp is High definition ready and will acept Sky high defiinition TV when introduced in 2006. Does anyone know if philips is a capable of HDTV.
    Still unable to see the philips in a high street store. Only seems to be available on the net. anyone seen it yet
  2. darktherapy
    darktherapy
    I am having exactly the same dilema. The Philips now comes with Pixel Plus 2, but I haven't seen the set.
    Has anyone seen the Sharp and the Philips together?
  3. eHuggy
    eHuggy
    From what I can tell, you can get HDTV through the DVI connection on the Philips. Next question would will be whether Sky release a HD box with a DVI connection on it?
  4. jgrg
    jgrg
    Oct 19, 2004
    557
    28
    Cambridge
    +36
    Don't think that the Sharp will accept HDTV through its DVI connection, which is intended for PCs.
  5. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    The Sharp definately takes 720p via its DVI input from an HDMI equipped DVD player, including CP material - ie its HDCP compliant. However, there are issues with some sources at 1080i. I couldn't get it to work with my DVD player and Sharp have admitted an issue in this respect.
    -Ian
  6. Digitised
    Digitised
    Oct 11, 2004
    177
    +13
    the 9986 is an amazing tv, and i believe the actual screen itself is made by sharp.
    the resolution is very good 1400x770 ish and it is ready for hdtv.
    the blacks are nice and dark, the response rate is brilliant @ 12ms
    And also, what i thought was just a gimmick has turned out to be one of the best innovations in modern TVs yet,
    AMBILIGHT
    its very responsive to the action on screen, it matches the colours very accurately and responds pretty much perfectly in sync with whats happening on screen.
    Bullet flashes and lightening strikes light the room up for that exact split second, and explosions just have to be seen.
    I think it has 1 over cinemas personally, id rather stay in now lol
    the sharp really wont match it, i have all my faith in this TV.
    PS - good luck trying to get a 37 inch lololol
    the 32 is large enough tbh, if you are sitting up to 8ft away the 32 is perfect, anything larger would expose its painting like image.
  7. Eyeball
    Eyeball
    Aug 3, 2004
    121
    16
    London
    32PF9986 get my vote for sure!
  8. Jimbo73
    Jimbo73
    Aug 22, 2004
    202
    +15
    JL in Reading had the two sets next to each other IIRC. Of the two, the Philips wins my vote!!
