philips or sharp lcd
Discussion in 'Philips TVs Forum' started by andyo, Aug 25, 2004.
Tags:
  1. andyo
    andyo
    Hi all
    I am torn between buying either the philips 9986 or the sharp LC32GA3E. I cant find either of them in a local retailer to view and have not seen any reviews for the sharp yet.
    the philips is £250 more. Is it worth the extra money?
    I want to connect my pc, what would the quality be when using my pc as a dvd player? I e-mailed philips and they said vga to dvi would give the best picture available. Is this correct? better than progressive scan?
    does anyone have any experience with either of these two tvs and should i buy a seperate dvd player? I would appreciate any help. thanks
  2. Eyeball
    Eyeball
    Aug 3, 2004
    121
    16
    London
    Sorry...the guys on here must be bored of me offering the same advice over and over.
    The Philips LCD is definitley the better one to go for and for £250 more you're getting a much better TV.
    S
  3. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Eyeball. What do you make that judgement on, what are the differences?
    -Ian
  4. jdl
    jdl
    Feb 4, 2004
    139
    Athens Greece
    +3
    Well for start the 32PF9986 uses a Sharp display but the 32PF9986 has MUCH BETTER electronics to drive that display (Pixel Plus 2, Digital Natural Motion) than Sharp's tv. :cool:
  5. Jimbo73
    Jimbo73
    Aug 22, 2004
    193
    +5
    I've seen the 32" Philips in Comet, Hayes and it is in a different league to ANY other display I've ever seen. Truly amazing. They had it hooked up to some cheapo DVD player and still the resulting picture was awesome. The picture was so clear and crisp that you felt there was an element of 3D there. Loved the "ambilight" feature too - seems like a gimmick but looks so cool when it's in action.
    I wanted to get the 42" version but couldn't stretch to the 4,600 price tag.
  6. jackylad
    jackylad
    Jul 20, 2004
    161
    16
    Has anyone seen the new 37" version of these screens yet?
    I've been waiting for Philips to launch it for months now and they said it will be available end of August.
    Any views on this would be great!
  7. andyo
    andyo
    thanks for the advice. I will definately buy the philips.
    anyone have any experience of using a pc as a dvd player. For 60 quid i can get a pci card with freeview, harddrive recording+timeshift. would this give the the best picture quality available as philips customer care told me?
    i think i can use powerstip to display a resolution of 1366x768. (and ive just got the new radeon x800 so cant wait to play games on it)
  8. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    The Philips will not accept native resolution at 1366x768. Philips recommend using 1024x768@60Hz. the full list of supported resolutions are:
    640/720 x 480p
    720 x 576p
    1920 x1080i
    1280 x 720p
    640 x 480 60 Hz
    800 x 600 60 Hz
    1024 x 768 60 Hz
    -Ian
  9. andyo
    andyo
    bugger
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I would go the Sharp IMHO the GD is better, but have you seed the Panny Veira? 32"??? Superb, Sharp Titanium has DVi-I so is very flexible!
  11. Eyeball
    Eyeball
    Aug 3, 2004
    121
    16
    London
    Where did you get this info from? Seems to be incorrect.
    Flatdeal.com and comet.co.uk have both this info on their websites and quote a resolution of 1366x768.
  12. neiljones
    neiljones
    May 29, 2002
    469
    northwest
    +13
    Saw the 32" 9986 in a Curry's superstore - the display was not wall mounted.
    The salesman displayed the various coloured ambilight sequences to me but because the set was not wall mounted I could not see the point of the extra expense. Nothing was achieved.
    The process basically is light tubes vertically on the sides to the rear of the set covered by serrated plastic - various coloured light settings could then be selected.
    Mounted close to a white wall the reflected colours would obviously be seen, but otherwise to no avail.
    Anyway has anyone seen the 37" or 42" 9986 LCD
    it is now the end of August- they were promised much earlier
  13. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Its direct from the 9986 manual.
    1366x768 is the native panel resolution, but the set cannot receive an input at this resolution, only those mentioned.
    It is likely that the Sharp will have the same limitation.
  14. duncs
    duncs
    Whats the point of that. If I buy a 1366x768 screen I want to be able to input at that resolution. I was thinking about buying one of these screens but will reconsider if I can't use the native resolution.
  15. mr-monday
    mr-monday
    Jul 19, 2004
    428
    28
    +31
    Have you considered the Sony KDL-L32MRX1? It got a favourable review compared with the Phillips in What Video and Widescreen TV. Despite the £4,300 rrp ( :suicide: ) it has already dropped to just over £2,600.
    Still a considerable outlay though. I'm going to wait a bit longer!
  16. robinho
    robinho
    Aug 9, 2004
    30
    High Wycombe
    I'm also looking to by a Sharp so have looked at its manual (http://www.tradenet.sharp.co.uk/files/Consumer_Electronics/LCD_Television/LC32GA3E/LC32GA3E428.pdf) which says that it will support:
    640 x 400
    720 x 400
    640 x 480
    848 x 480
    800 x 600
    1024 x 768
    1280 x 720
    1280 x 768
    1280 x 1024
    640 x 480 MAC13"
    1024 x 768 MAC19"
    832 x 624 MAC16"
    1366 x 768
    It also has a mode to ensure dot for dot when displaying PC output.
  17. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    If that is confirmed that is :clap:
    I hooked my DVD player with internal scaler today to an old DVI PC monitor with 1600x1024 screen as an experiment. I know this monitor will not accept native but will do 1280x720p@60 (had to put it into NTSC mode). Well, with auto resolution detection on it wanted to put out 1600x1024 which the monitor refused to synch with. Crazy that the EDID reports 1600x1024 but will not accept that input. Even so, im pretty convinced that the DVD player is going to allow me to scale to 1366x768, all I hope is that the Sharp will allow this at 50 and 60Hz.
    -Ian
  18. ANTHONYVEE
    ANTHONYVEE
    Hello,
    I also need advice, I have the option (within my budget of under 1500UKP) to buy either set, I have read that the Philips is great with the pixel plus 1, but is the new sharp set inferior ?
    Is it worth the extra 400-500 for the philips 32PF9986 ? :lease:
    AV
