Philips Ondigital box - why can't I change channels?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Bert Coules, Apr 11, 2003.
  1. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    I'd appreciate any thoughts or advice on this:
    I've just acquired a Philips Ondigital box, but I don't (as yet) have a remote - one's on its way via eBay.
    When I first powered up the box, the "M" (Menu) and "S" (Select) front-fascia buttons worked perfectly and the box found and stored all the available channels with no problems. Unfortunately, now I can neither change channels nor re-access the menu - the box is stuck firmly on BBC1 and all of the front buttons seem to be dead.
    Is it the case that you must have the remote to change channels or get to the menu, or should those front buttons be working?
    Help!
    Bert
    www.bertcoules.co.uk
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    i have a nokis on box and the front buttons do naff all it might be a software thing. but I am sure someone with the Phillips will be along shortly
  3. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    Thanks for the speedy reply.
    What's puzzling is that the Select and Menu buttons worked perfectly when I first plugged the box in, but now have no effect at all.
    Bert
  4. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    The buttons on my Pioneer don't do anything either.
    I can't say I tried them before storing channels but its possibly just a software glitch.
    Have you got a OFA remote you can use?
  5. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    I tried my Home Theatre Master universal remote, but couldn't find any code which got a response from the Philips box. I'll give it another go.
    Interesting about the buttons on your Pioneer not working either. A curious sort of feature...
    Thanks for the reply.
    Bert
  6. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Bert have you tried switching the phillips on and off
    My box frequently crashes and gets stuck on a channel and the remote doesnt then work. Only solution is to switch it off and on again
  7. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    I've tried switching on and off, and also unplugging from the mains. No effect, unfortunately.
    I should be getting the proper remote in a couple of days; I'll see what happens then.
    Bert
  8. shawkins002
    shawkins002
    Dec 12, 2002
    237
    Epsom, Surrey
    I've heard that on some exITVD boxes, when there's an MHEG layer on the current channel, the front panel buttons stop working. Try unplugging the aerial so it loses the MHEG data, and see if it changes channel then.
  9. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    Shawkins002,
    Bingo. With the aerial unplugged, the front buttons all work correctly. If I call up the channel list, scroll down to (say) Channel 5, press select and then plug in the aerial - up comes Channel 5.
    Unfortunately, the minute the aerial's plugged in, the front buttons stop working again.
    But at least I now know that the box isn't faulty. And hopefully, the remote will work.
    Many thanks for the tip.
    Bert
  10. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    Bert, I've just got rid of a Philips OnDigital box, but it behaved exactly as you describe. You'll be glad to know that it worked fine with the remote.
  11. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
