Supermal
Established Member
Used the same settings as you with my 4k firestick but still shows 8 bit on the three formats when i check using info button on tv remote.View attachment 1329700
No problem, yeah it's straight to hdmi, make sure you've set your hdmi socket to optimal as well.
Decided to try my 2015 shield tv and that shows 10 bit for disney + and Amazon prime!Also bt.2020 which is also correct.So problem seems to lie with cube2 and firestick 4k settings.I will have to investigate further.
The tv info looks to be working as it should at least.
