Quantcast
Philips OLED+ 934 4K TV Hands On Review & Comments
SimonHavfc
Great preview, many thanks.
This TV could be a great alternative to the GZ2000.
SonOfSJ
@Steve Withers Greetings, Mr Withers! For me the most important paragraph in your hands-on review is:
"Philips has wisely decided to take an agnostic approach to high dynamic range, which means the 934 supports HDR10 (just like any other HDR TV), Hybrid Log-Gamma (HLG), HDR10+ and Dolby Vision. The inclusion of the latter two means users will be able to enjoy the benefits of both dynamic metadata formats. This approach will give the 934 an edge over much of the competition because most manufacturers (apart from Panasonic) support one format or the other. "
Let's hope that Philips (and Panasonic) can inspire Sony and LG (Dolby Vision only) and Samsung (HDR10+ only) to become HDR agnostic, because surely why would an AVForum member not limit themselves to Philips and Panasonic? I hope to buy a very large (85" or 88") television in about two years time, maybe just before Christmas 20121, currently I'm not fussed whether LCD or OLED, but I certainly won't be buying a television that can't play all HDR formats.
Back specifically to the Philips OLED 934, this is decent value at an initial price of £3K for the 65-inch, especially since it is £1,500 cheaper than the 984 (which admittedly has a better sound system, but the same picture quality). It should sell very well.
philipb
Steve
Sorry to be a clever dick, but if Philips were agnostic towards HDR, it would mean they don't believe in it. I think you mean eclectic.
JetsetDruid
Steve
Nope - agnostic is used correctly in this review, this usage would refer to "platform agnostic" which is;
a concept that refers to the design attributes and philosophies of software products. A platform agnostic product runs equally well across more than one platform.
Also for the record agnostic doesn't mean you don't believe in something it means you are unsure if it exists but you are open to the possibility of it either existing or not existing.
Iron Monkey
Definitely looking forward to seeing some reviews of this, looks like a great bit of kit and definitely on my shortlist...I'm knocking the Panasonic TVs off the list unless they fix Cracklegate soon - and not sounding hopeful over on the GZ2000 Owners thread - I spent the first half of 2019 waiting for that model to be released but sounds like a patchy experience for early buyers so far, which isn't great considering the price :(
No mention of HDMI standards but I'm guessing not 2.1 or supporting ALLM etc? LG are adding in Nvidia GSync support on their 2019 TVs too....E9 is looking like a good choice for a movie/gaming usage mix. Either way I think my shortlist is down to the E9 and this Philips. Black Friday is going to be interesting :D
Gazgum
Mmmm...outboard speakers! Could these be the first consumer OLEDs that can be used more like monitors for those of us who don’t want the built-in sound gubbins?
Picture will have to beat the GZ950 by around £500 worth (allowing for some price flexibility) to make it viable though;not a small ask! And that’s with Philips’plethora of unnecessary processing turned off.
philipb
Which would be true if Philips were software or hardware, but it's not.
And I'm pretty sure that Philips don't harbour any doubts that HDR exists. Indeed they believe in all 3 of its incarnations - HDR10, 10+ and DV. A (un?)holy trinity.
Steve Withers
Reviewer
Agnostic is correct within the context I was using it. You forgot Hybrid Log-Gamma and Technicolor (although only LG appears to believe in the latter).
Steve Withers
Reviewer
I do mention that the 934 uses HDMI 2.0b and that it supports ALLM. Perhaps a second read is in order?
Strator100
This TV has joined my interest zone along with the Panasonic GZ2000 and LG E9 (I use the onboard sound more than any off board solution I've cluttered lounge up with). Looking at the Philip's website they have manuals for the 934 linked already. If this link works: 934 manuals could help answer lots of questions 👍
JetsetDruid
Well Phillips make hardware that also runs software so I think my platform agnostic link is apt.
You are correct on your second point though, agnostic can also be taken to mean "prepared for any eventually" perhaps that better fits?
Strator100
The user manual shows it as a fixed bar that attaches to speaker enclosure which just gives a T shaped footprint. There is no hinge visible so looks fixed, probably for stability as much as cost...
Tjiko
I love the tv, but I'm unable to get my tv-channels in the android launcher(channels).
I can watch tv, thats no problem. I can add netflix,disney and kodi to the launcher(channels), but not my tv channels. I love to have the tv channels on the home-screen. Does anyone know what I'm doing wrong?
(It's via cable/dvb).
clnthl
not until mid October, picture is the same as 804 and 854 which we should start seeing reviews for this week/next week. I would say don’t expect any reviews on the 934 till very late October or more likely November.
AdtAdt57
I’ve heard Danny Tack mention years back that while Philips may not adhere to HDMI 2.1 they do/will add some features of it? As others have mentioned I’d be interested in using this as a monitor, i.e. without a Soundbar getting in the way of my centre speaker of a mid/high end AV System.
As builtin Apps are now able to deliver Dolby Atmos and other advanced audio I really need eARC to get this sound to my AV Amp, which is not mentioned for any of the ‘new’ Philips TVs. This is part of the HDMI 2.1 Spec, I understand as is HDR Dynamic MetaData needed to get HDR10+ & Dolby Vision into the TV via HDMI. So why are these features never mentioned or commented on as urgently needed?
Does Philips expect all owners to just use the builtin sound, while Dolby 2.1.2 is in some TVs it’s no match for a mid/high end AV System. What Philips TV am I expected to by next, as the 9002 never did get the promised HDR10+ via HDMI, only via Apps which never worked for me, plus after more than a year of use I lost the builtin BBC iPlayer App that could use HDR HLG...
... anyone know of a new 9000 series on the cards?
Steve Withers
Reviewer
Just for the record you don't need eARC to pass Atmos from the TV back to an AVR or soundbar, you can do it with normal ARC because these apps deliver Atmos using lossy Dolby Digital Plus and not lossless TrueHD.
jasehigh
Does the 55" 934 have a subwoofer pre out. Would be very interested in this TV if the a separate sub can be added.
Similar threads
Trending threads
Latest News
Sony XH81, XH80 and X70 TVs now available in UK
  • By Andy Bassett
  • Published
TV sales rise as UK stays home
  • By Andy Bassett
  • Published
AVForums Podcast: 30th March 2020
  • By Phil Hinton
  • Published
UK telecoms come together to keep country connected
  • By Andy Bassett
  • Published
Sharp and NEC display venture to push 8K + 5G tech
  • By Andy Bassett
  • Published
