Christian1979
Hello
I have two questions about the Philips OLED TV:
1.) Motion interpolation.
Here in this video you can see at position 14:00 clear artifacts in movements:
Has this been fixed in the meantime by firmware updates (or with the new model)? Or is it still that bad?
2) Status bar during a frame rate switch (HDMI refresh)
When the TV performs a framerate switch (frame rate adjust on AppleTV zb). Is there then a bar with "HDMI 1" or an indication of the resolution, frame rate or something like that? Or is such a switch simply executed cleanly without a "message"? Or if a message appears, can this be completely deactivated via the settings?
Many greetings,
Christian
Many greetings,
Christian
