Philips Monroe- Does anyone have one yet
Discussion in 'Projectors, Screens & Video Processors' started by DRC, Jan 14, 2002.
  1. DRC
    DRC
    Has anyone got a Philips Monroe yet, before xmas there was a number of threads but I have not seen anything since.
    A number of mags seem to give it good reviews.
    I would like to know as I am thinking of ordering one in the coming days
  2. dasithlord
    dasithlord
    I've just ordered one from Germany, to my surprise it cost only 2700 EUR there...
    I've seen it in action a month ago here in Belgium, and i was really impressed with the picture quality !!!
    I've seen TV, video and DVD and even the quality of normal TV broadcast (cable) was really outstanding !
    And the DVD player was only connected using compsite, so s-video and rgb inputs can only be even better :))
    Given the 6000h lamp life, and the pal/ntsc progressive scan capable VGA input, this is really a nice projector.
    I'll post a review here as soon as i was able to test it completely.
    Greetings,
    Nicolas
    Ps: you can order it here: www.grossbild.de if you want it immediately...
  3. magnust
    magnust
    I've had one for about two months and I'm very happy with it.
    Before buying I compared it with the Sony HS1, Sanyo PLV-30 and the Liesgang dv 245. These are projectors in about the same price-range and i found the Monroe to be the best of them.
    The biggest issue I had with the other models were screen-door effect of which the Monroe suffers significantly less from. Philips has managed to make their pixels have a very high fill-factor which makes less of the "grid" visible. Other plusses for me are: very accurate colors, ceiling mountable and 6000 hrs lamp life. The noise level at 32 dB is quite acceptable, although I wish it was a bit quieter.
    The only caveats is that some of them make an annoying high-pitched noise in stand-by mode, and to a lesser extent when the lamp has warmed up. The seller told me that this is a fault with the lamp and that Philips should fix the problem as a warranty issue. I got one that had this problem and got the entire unit replaced.
    The other caveat is that the component input requires a composite sync, i.e. it's not enough to connect the y/pb/cr; one also needs to connect it to the composite out of the DVD. Philips will change this in the next revision, but couldn't/wouldn't tell me when that might happen. The downside is that it currently needs four cables instead of three (or a vga-> 5 bnc cable).
    All in all I'm very happy with it.
    In Regards,
    Magnus
  4. infomatique
    infomatique
    I received my Philips Monroe yeaterday. I purchased in in Germany from ComputerUniverse.Net and saved about Euro 2000 (relative to what I was quoted in Dublin). I also purchased the I-SCAN PRO from another source in Germany.
    I must admit that I am very impressed by the Monroe (with or without the I-SCAN) and would recommend it.
