Hi looking for some help
With the philips you have to use StreamiumCafe to add internet radio
i have enter the info at the StreamiumCafe for heart FM Essex and all is ok on the MCI500H work fine.
Then when you try to play it on the Was7500 Unit on luck any Help
I have tryed getting help on Philips forums with no luck
Would Just like to no if iam missing some setting or somethink for the Was7500
