Philips lx3900 region free
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by fpallino, Oct 10, 2004.
  1. fpallino
    fpallino
    Hi to everybody
    I have a philips lx3900 and my prb is to use some dvd form us.
    I'm looking procedure to permit to use "region free" or us area (1)
    thks
    franc :lease:
  2. Steve63
    Steve63
    try this one, its for the philips dvp520, if i remeber go to the "Preference Page" in the System Menu and enter "135566" to get to the hidden Region Code Menu. (Prefrance menu is in the one with the small TV type logo with the Tick on it.) Set it to (0) ZERO using ya up-arrow key.
    Then exit menu to save code...Thats if the menu is the same as the DVP520 menu, only can but try...try a regional 1 DVD (A USA DISK)if it work then you player will now be regional free.
    Let us know if it works or not.
    Steve63
  3. beefy032363
    beefy032363
    for those of you that are having problems with the multi region hack for this system all you have to do is open tray place the region 1 disc on the tray and press 99990 on your remote and then press play and that is it heypressto multi-region hope you all enjoy :clap:
    have done this on my system and it works
