Philips LX3750W Optical Out Problems
Discussion in 'Home Cinema Buying & Building' started by BritanniaJaf, Feb 4, 2005.
  1. BritanniaJaf
    BritanniaJaf
    Jul 12, 2004
    4,041
    Glasgow
    +265
    Can somebody please help me with the above system. Have connected a digital optical out from my sky+ box/ntl/xbox etc and choose the the aux/out option on my amp but no sound whatsoever, yet when i connect normal audio leads and choose the aux/ana option i get sound fine, is there something i have not activated on my machine, Please help
  2. gpearce
    gpearce
    If the system works the same way as the 3900, then you need to press AUX twice as it actually switches between AUX (analogue) and DI (digital). DI is what you need.
    Also, isnt there a setting on a sky + box to enable the digital output? I think you need to check in SYSTEM SETUP > AUDIO or something.
    HTH
    Gerry
