Philips LCD's - progressive scan but no component inputs
Discussion in 'Philips TVs Forum' started by nelliott, Sep 24, 2004.
Tags:
  1. nelliott
    nelliott
    Dec 21, 2003
    37
    Hi. Am looking to buy one of the newer Philips LCD's (possibly the 23pf9946) but am a bit confused about how I could feed it a progressive signal. The tv's come with scart, s-video, dvi and vga inputs so I guess I'd have to use the dvi socket for progressive scan?
    Can you get a component to dvi-i cable?
    Thanks in advance.
  2. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    yes
  3. nelliott
    nelliott
    Dec 21, 2003
    37
    Great, thanks (er - yes to what?) :)
  4. reckless
    reckless
    Dec 21, 2003
    987
    28
    +30
    I think he meant you can get the cable that will enable you to send component from your dvd player to the dvi socket on the set.
    Could be wrong mind :)
  5. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    Try Keene.co.uk, I know you can get YUV(component) to VGA, my Kiss DVD player will output to VGA via its scart
  6. nelliott
    nelliott
    Dec 21, 2003
    37
    Thanks for the replies. Looking around I think I could get a component to vga, then a vga to dvi cable which should work.
  7. alasdair
    alasdair
    May 14, 2004
    81
    glasgow
    +17
    The relaunched 32pf9986 comes with a Dvi to VGA adaptor & a VGA to component cable; mine didn't come with it however a phone call to Philips sorted that out; however i now can't get it to work !!
    If anyone has any ideas.....
    using a hi-def xbox connection (on a modded machine) & just getting a blue screen...
  8. baku
    baku
    the US version have HDMI and component input + Pixel Plus, while the EU version only have scart,DVI but no Pixel plus :thumbsdow :mad:
    will it work to play or watch PAL dvd/xbox/ps2 games on a NTSC LCD TV???
    I want the US version not the crappy EU version..
    Edit: eu version response time is 25 while the US is 16 :/
  9. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    EU refresh rate is 50Hz, US is 60Hz.
    At least that might be the argument they use for lower specced panels.
    TBH, I don't think its worth getting stressed about the response rate if its a good panel. There are some great 25ms panels, and some crap 16ms ones.
