Philips LCD TV turns blue when i turn on my xbox!
Discussion in 'LCD & LED LCD TVs' started by The_Swede, Apr 30, 2005.
  1. The_Swede
    The_Swede
    Hi this is my first post here :hiya:
    I have just bought a 32" Philips LCD TV Philips 32PF4320/10 in Sweden.
    I have it connected like this:
    Scart 1 (RGB)=Xbox with a MS original Advanced Scart RGB Cable.
    Scart 2=DigitalBox and i have my Yamaha DVD S550 connected through the digitalbox´s scart 2.
    My problem is that when i start my xbox the screen sometimes turns completely blue,if it doesn't turn blue it's scrolling so i barely can't see the picture.And if it starts okay then there is blue lines around the text and objects.
    This is my second LCD because i thought the first one was defective but now it's the same on this one.
    I had a 26" Philips LCD TV and it was the same with that one.
    My xbox works fine on a regular TV with the same scart cable.
    :lease: help me out on this.
  2. drskhaled
    drskhaled
    Feb 25, 2005
    1,541
    London
    +108
    try changing the framerate on the xbox to 50hz to see if that helps. you can do it via the xbox dashboard. My lcd did a similar thing but with a purple screen. But now it seems to work fine on both frame rates not sure why, oh and i have the official rgb scart too. Failing that there may be an option on your tv to accept the various video inputs (ntsc, pal 50/60 etc).
  3. The_Swede
    The_Swede
    Hi,well my xbox is on 50Hz and i can't seem to find any such options on my lcd tv.
  4. The_Swede
    The_Swede
    Anyone else who have the same or know what is wrong..
  5. Rob1698
    Rob1698
    Either the sync rate is wrong (but you say it is 50 Hz), or the cable does not output a correct sync signal to the SCART connector.
    There is some trickery involved in converting a VGA signal to SCART RGB so this is where it might go wrong.
    I don't know the XBOX so I can't tell you much more...
    A regular TV often accepts more errors than a digital TV.
  6. The_Swede
    The_Swede
    I have seen this sympton only on philips lcd tv though.
  7. The_Swede
    The_Swede
    Here is a picture of my xbox´s ms dashboard.
    The blue line is much more visible when i look at the screen instead of the picture i took.
  8. machinehead
    machinehead
    Sep 5, 2004
    465
    Greenock
    +12
    wouldn't be a dodgy lead perhaps?.just a thought.
  9. The_Swede
    The_Swede
    The thing is when i play on the xbox the blue line isn't there or when watching a dvd on scart 2 i never get this blue lines either.
  10. The_Swede
    The_Swede
    What is a "dodgy lead"?
    It looks like the rgb allignment is out of order or something.
    This sucks when it's brand new and my second one with same thing :mad:
  11. The_Swede
    The_Swede
    I have now connected the xbox alone to the tv.This is defently a rgb problem on this lcd tv.I have tested with 3 different xbox RGB cables.
    If i have it connected to EXT1 (Scart 1-RGB) i got the blue lines.If a play a shooter the crosshair has different colour around it when i highlight something.Look at the pictures.
    Connected to EXT2 (Scart 2-non RGB) i have none blue lines but not a good picture because of the non rgb scart.
    Can't i fix the rgb so they are good in some way?Service Menu or something like that.
  12. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    It is extremely unlikely that this is a TV problem - especially as this TV is showing the same problems as your previous one(s).
    It's your Xbox. Bound to be. I assume you know that the Xbox is outputting RGB? Ext1 and Ext2 are both RGB, it's only Ext3 that is Composite.
    Does your Digibox and DVD player work properly through Ext1 and 2? I bet they do.
    Have a major fiddle with the Xbox and possibly try different feeds from it. Even RF!
    The TV will be fine.
    Jimmy
  13. The_Swede
    The_Swede
    I have 2 xboxes and both are the same on this LCD and not on the other lcd i got.This philips hasd only got 1 rgb and thats on EXT1.
    I'm gonna check right now if the dvd has any problems on scart 1 rgb.
    What do you mean by even RF and fiddle with the xbox,you can't change so much on it.
  14. The_Swede
    The_Swede
    Okay,just tested to put my dvd on scart1 and it has the same fault.
    Now what?
  15. The_Swede
    The_Swede
    I just noticed a thing,if i pull the powercord off for a while the blue screen comes all the time i try to boot the xbox then on like the tenth time it boots normal.The rgb scart is driving me nuts :mad:
  16. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    Sorry Swede, I haven't been much help. I just don't understand how you can have the same fault on a number of TV's without it being the source. Yet you get the same fault with both your Xboxes...most of the time...and now your DVD player too....Jings!
    You haven't got a really bad power supply have you? I have heard of people having to clean up their power supplies in order to sort out this kind of mysterious problem. There are cables available to do this....just a thought.
    Jimmy
  17. The_Swede
    The_Swede
    No man,every thought or idea is good.
    Well i took another long powersupply that i plugged in the kitchen and just hooked up the TV and let everything else as it was.
    It was the same,no difference.
  18. The_Swede
    The_Swede
    Can someone confirm that this is a RGB alligment problem?
    Also have noticed that the blue ,red are shadow or what to call it are visible when connecting through S-Video too but not so visible as on the RGB scart input EXT 1.
    Can't this be fixed through a service meny or something?
  19. The_Swede
    The_Swede
    Man i got tired of that crap tv and went back with it and bought a regular CRT.
    I bought the Philips 32PW9509 with Pixel Plus 2 etc.
    WOW!What a picture,damn!!When you watch a dvd or play the xbox it looks like they are about to jump out of the screen,wow :smashin:
    I'm so glad i took that one instead.
  20. The_Swede
    The_Swede
    Update on the LCD TV.
    Philips called me and said that the engineers say's the TV has a problem and that the Philips 32PF4320 series got this problem or that the shipment my dealer got had it!!
    Good to know.
    Well i'm now a happy owner of another nice tv and it's flawness,lol so i don't really care anymore or atleast i don't have the will to do so.
    Btw,thanks Philips for reading my topic. :hiya:
