Philips LCD Question
Discussion in 'Projectors, Screens & Video Processors' started by chieflenny, Aug 20, 2005.
  1. chieflenny
    chieflenny
    Just got a great deal on a Philips LC 4331 LCD projector. The reason for the great deal is because there is a yellow strip on the top of the image and a blue strip on the bottom. I have a feeling something is burned into the LCD, but I am not an expert.
    Does anyone know what is causing it and if it's possible to fix inexpensively? I can watch anything in a 16:9 ratio and have no problems, since the black bars are in the same position as the blue & yellow ones. Once I change to full screen, the discoloration gets annoying after awhile.
    Thanks for your help!
  2. mgzr1400
    mgzr1400
    Aug 14, 2005
    42
    what cables are you using and where is the projector positioned?
    i will try to help if i can because ive just had a philips too on friday so im all new to this too
  3. chieflenny
    chieflenny
    So far I have tried it with the Data (VGA) cable from a PC and also S-Video cable from my DVD player. It doesn't matter where it is positioned, from what I have seen so far.
    Are your Philips doing the same thing?
  4. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    If the areas of discolouration match the black bars it might be something akin to screen burn. If it is, you are probably stuck with it....PJ :)
