Philips LCD 40PFL5505D/F7
doughsmurofva
Joined
May 1, 2011
Messages
Reaction score
Points
Distortion question?? When viewing my new 40PFL5505D/F7 LCD set, when watching baseball for example, the ball appears to be distorted at certain times. For instance, when the 3rd baseman throws across the field to 1st base, as I watch the ball move across the field, two or three balls can actually be seen....same thing if a left or right fielder throws the ball into the infield, if the ball travels across the tv screen, it appears to be distorted. It happens while watching golf also, it higher speeds the ball is distorted. I am watching in hi-def using a Philips HDMI cable. I'm a bit confused since research suggested that this 240hz tv set would all but eliminate this problem. Is there a setting I am missing here? This is my 1st LCD. Can anyone help?
this is Natural Motion algo problem,
some small object can be distorted when backgroun around it moves to oposite dirrection
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
