Philips iPronto - when is it charged
Discussion in 'Home Cinema Control & Remote Controls' started by lscolman, Aug 13, 2005.
  1. lscolman
    lscolman
    Jul 31, 2003
    6,749
    Tyne & Wear
    +141
    Just bought an ipronto without mains adaptor. The mains adaptor has arrived and the manuals states that it is charging when all the lights are lit on the battery bar.
    How do you know when the battery is fully charged?
    Any help would be appreciated.
    Cheers, Lee
  2. ms2004
    ms2004
    Aug 6, 2005
    10
    Look in settings and the battery bar is at the top. When all the bars are lit its charged. If its still charging, the bars will be still be moving to the right.
  3. lscolman
    lscolman
    Jul 31, 2003
    6,749
    Tyne & Wear
    +141
    Can I ask where the settings menu is? The only battery bar I know of is the one in the LCD windows on the front of the unit. That one lights up with all bars showing as full whenever I plug it in.
    I'm not sure where the settings, with the battery bar is. Can you help?
    Cheers, Lee
