Philips Hue switch??
Discussion in 'Smart Home, Climate Control & Security Forum' started by a l e x, Apr 21, 2016.
Tags:
  1. a l e x
    a l e x
    Jan 3, 2009
    7,772
    East Yorkshire
    +2,608
    Evening all, looking at getting some Philips Hue bulbs at home.
    One main question... What happens to your light switches?! Do they still function? If you have hue installed and flick the switch does it turn it off or are they useless?
    Some of our light fittings are 3 bulbs. Can you add 3 bulbs to one light and control them all with one action or do they need turning on/off individually?!
  2. se99jmk
    se99jmk
    Jan 31, 2011
    178
    +31
    Good question!
    Your existing light switches are not recommended.. They will turn off the lights (but means they cannot be remote controlled), and turning back on will return them to default white light.
    Personally I twisted the wires together inside the wall switch (always on - or you could blank off the switch), and use the Philips Hue Dimmer switch, which is sticky-backed and you can stick up anywhere.
    Re-three bulbs - you can group them together. The Philips Hue app supports "rooms", and Siri / HomeKit supports "groups" within "rooms", so yes you can tie different bulbs together if you like.
  3. a l e x
    a l e x
    Jan 3, 2009
    7,772
    East Yorkshire
    +2,608
    Nice one, thanks for the quick reply.
    I really want to get Hue but just not sure it's worth it for me. We have 3 switches for the hallway and 6 bulbs. Some of the switches control upstairs and some outside lights so would have to put a few blanking plates on the wall and change some switches around. Thinking about how many bulbs id need plus the switches (the gf would refuse to just use her phone!) it looks like it'll cost a fair amount!
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    Ive always said dont like the electronics built into the bulb, it should be at the switch or elsewhere.
    Do you really need colour in the hallway
  5. mudshark
    mudshark
    Sep 14, 2006
    3,624
    +1,297
    Not disputing what you are saying but why do you always have this opinion?
  6. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    A bulb is a disposable item so throwing a lot away if it goes, or gets broken
  7. mudshark
    mudshark
    Sep 14, 2006
    3,624
    +1,297
    A bulb which is guaranteed for a year.
  8. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    I should hope so modern LEDS usually last about 5 years +
    Also not if you drop it or a power surge blows it though.
  9. Spraggle
    Spraggle
    Feb 11, 2016
    440
    2
    Manchester
    +82
    B&Q are doing the white dimmable bulb with screw fitting with the dimmable switch for £30 and the white bulbs for £15.
    That should reduce the cost a fair bit, if colour isn't required.
  10. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +336
    I just stick the dimmer next to the main switch.
    I would only want an adapted switch that keeps the physical switch.
    From a safety point of view it is important to be able to bypass the "smart" function in an emergency. People will instinctively flick a light switch a couple of times to get the light to work.
  11. CharlieVictor
    CharlieVictor
    Feb 24, 2018
    5
    UK
    I think they are a little bulky, but when in situ look great. I can access the switch still and is a cheap alternative to smart wired in switches. I’ve changed most of mine now.
  12. Inked
    Inked
    Jan 3, 2006
    17,544
    17
    2
    Behind you
    +7,159
    I got mine for this seller on eBay, the original switch is still easily accessible through a cutout behind the Hue remote which is just magnetised to the cover
    Items in 3D Print Concepts shop on eBay.
  13. CharlieVictor
    CharlieVictor
    Feb 24, 2018
    5
    UK
    They look okay and I like that they have different thicknesses, but the height makes them look like the dimmer switch has been stuck over the top of a normal switch. What are they made from?
    I bought one from etsy from DFX and it was similar and ABS which was warped so not flush to the wall, so didn't use.
    I'm more than happy with the ones from eBay seller 1xxxxxxxxxx, who always seems to have stock. I prefer the shape and they also have an access hole. Some light switches are thicker than others and fancy ones have details, hence the extra bit of clearance behind.
  14. Inked
    Inked
    Jan 3, 2006
    17,544
    17
    2
    Behind you
    +7,159
    I had a look at those, but they looked big and bulky which put me off.
    In your picture further up it looks huge and that the dimmer then sticks out even further.
    The rounded edges of the one I have makes it look less boxy, even though they probably stick out roughly the same amount overall.
    CFBB235F-95F0-4D54-99DC-0186732E4A1F.jpeg 94B6D96F-43B6-4ABA-90AC-9B2667E63C58.jpeg 7399BA6C-F98F-4348-83E6-86316BF5ACBA.jpeg
  15. Inked
    Inked
    Jan 3, 2006
    17,544
    17
    2
    Behind you
    +7,159
    Oh, and tell me. 1xxxxxxxx wouldn’t happen to be you would it @CharlieVictor ? Only you’ve only posted on AVF about those switch covers and the eBay seller used to have a username of biddercv which seems rather too much of a coincidence for those of us with a suspicious mind.
  16. Sonic67
    Sonic67
    Sep 14, 2006
    43,179
    11
    167
    Home
    +21,177
    As an ex sparky, not recommended. You always need a switch for isolation. What if there is a fault with the fitting, or you want to safely change the bulb? Whatever the reason it's a requirement of the IEE Regs there is a switch for isolation. One that kills the power totally.
    If you want, switch it on and leave it. Or sometimes use it as a light switch. The worst that happens is it acts as a light switch and if off the light is off and switch on it comes on as a white light. That's it.
  17. CharlieVictor
    CharlieVictor
    Feb 24, 2018
    5
    UK
    Sonic67, I wholeheartedly agree! Safety first. I have a friend who did this and now he is refitting the switches and using switch plate covers after I informed him of their existence.
  18. Inked
    Inked
    Jan 3, 2006
    17,544
    17
    2
    Behind you
    +7,159
    I’ve just noticed your archived classified ad which confirms you are in fact the eBay seller. Why are you pretending that you’ve purchased from yourself? No wonder you are so happy with the product!
    Pathetic
  19. Apsilon
    Apsilon
    Senior Moderator
    Sep 15, 2006
    14,436
    Manchester
    +7,673
    @CharlieVictor, it's not really a smart move to promote your own eBay sales on here.
    Firstly, promotion is against the rules and if you wish to advertise, you have to pay an AA fee - which I'm guessing you don't want to do.
    Secondly, there are a lot of eagle-eyed members who also frequent eBay and will spot you from a mile away.
    Thirdly, it incurs a ban and - you're now banned.
    I'm leaving Charlie's posts intact purely because if I remove them, the thread will make no sense but, I have removed all links to his listings.
    As you were.
    • Like Like x 3
    • Thanks Thanks x 1
    • List
  20. LondonLesney
    LondonLesney
    Aug 28, 2017
    17
    London
    +5
    I can see the benefits from a safety perspective and it is convenient to have a local isolation point but is this really a requirement of the IEE regs?
    What about when no-neutral smart switches are used which are effectively permanently live? or even when lighting circuits are spider wired from a central control panel with a local switch/touchscreen linked to the central control panel, but not the lighting circuit, to control the lights in the room? Do these also require a local isolation point?
    I am never sure if local isolation is a requirement, good practice or we just do it because someone told us to...I'm not criticising your statement but I'm here to learn so I'm keen to understand.
  21. gathers54
    gathers54
    Nov 14, 2009
    2,710
    Wallington
    +181
    I purchased these, would rather these switch covers than two separate switches and I wouldn’t remove the standard switch. I think they look quite good. My only criticism is the magnet isn’t as strong as the backplate it comes with
  22. LondonLesney
    LondonLesney
    Aug 28, 2017
    17
    London
    +5
    What about if the switch cover came with an integral switch which replaces the standard switch, that way it could be more flush with the wall?
    I'm contemplating making an integral solution but not sure if the demand is there, probably in a gloss ABS rather than a 3D print matt finish.
  23. Inked
    Inked
    Jan 3, 2006
    17,544
    17
    2
    Behind you
    +7,159
    Sounds like a lot of effort and increased costs for very little gain. The existing style of covers work well enough and are unobtrusive IMO.
  24. LondonLesney
    LondonLesney
    Aug 28, 2017
    17
    London
    +5
    Good point...as you bought one, do you think there is a demand for these??
  25. Inked
    Inked
    Jan 3, 2006
    17,544
    17
    2
    Behind you
    +7,159
    Certainly seems to be, the seller I got mine from on eBay sells out pretty quickly. I contacted him yesterday as I need a double switch/single remote cover and they are apparently going back up for sale tomorrow at 7pm
