Got a new wall mounted TV and wanted to get some effect/bias lighting for around the TV. Was going to get Hue Lightstrip but saw the new Play Bar which looks great so ordered a kit plus extension.
All looked fine until I went to plug everything in and a for some stupid reason the power brick is upside down (to me) and the cables outlet the top when plugged into a standard UK three pin wall socket. There is just enough room behind the TV for the power brick and is hidden but when I plug the lights in you see the cables just above the top of my TV which drives me mad so have sent everything back.
The question is, does the power adapter on the Hue Lightstrip work in the same backwards way and the cable exits the top of the power brick when plugged in or does it drop as every other standard UK plug socket does? Don't want to have the hassle of buying stuff just to return it all again.
Many thanks in advance.
