Question Philips Hue E27 - Downlighter Fitment Options?
Discussion in 'Home Cinema Building DIY' started by Planter, Sep 19, 2018.
  1. Planter
    Planter
    Mar 6, 2011
    135
    Hereford
    +13
    So I have 9 Hue colour bulbs ready to fit in my lounge. They are the E27 fitment type, so not standard GU10, which seems to host about 99.9% of standard downlight fitments.
    So, my question is which downlighter fitment works for the E27 fitment as all the ones I see at the moment show E27 fitment but for R80, R63, R50 lamps and want to make sure they are correct and not oversized or random in any way.
    If any of you have E27 fitted in downlighters, do you have pics and then where you got them from/model numbers etc.
    Thanks in advance
  2. ufo550
    ufo550
    Sep 20, 2014
    1,393
    113
    Oxfordshire
    +768
    There's not many down lights out there that don't use a GU10 lamp holder.
    I've found these, but you would need to consider the shape of the lamp as to how it would appear out of the fitting. You could contact Click Scholmore to see if these luminaires are compatible with Philips Hue E27 lamps.
    Fire Rated E27 Downlights Click Scolmore | Downlights.co.uk
