I'm looking to fit the Hue Colour gu10 bulbs into downlights. Do you guys know any downlight housing that tilts and can fit the longer 71mm Hue gu10 bulb? Thanks.
I got mine from www.downlights.co.uk there are some that mentire philips hue in the description. Just search I think. They have tilt and swivel options too.
I've started buying INNR GU10 bulbs as they are much cheaper than the Hues. They are also shorter than the Philips ones so fit in the housings easier. Only come in white though.
The other option is just cut the socket bracket off and either extend it with a small piece of flat bar aluminum and pop rivets or remove it all together.
If removing you may have to insulate the socket as it will just flap around.
The Hue white ambient bulbs are superior to the Innr CT. Both of them are normal GU10 size so no issues with fittings and my Hue worked out no more expensive than Innr ones as they're frequently on offer.
TBH the Hue colour GU10s are a little disappointing. They don't have the colour range of all of the other latest gen, particularly green and blue.
