Philips HTS3548/98 and Any other Audio Amp
Discussion in 'AV Receivers & Amplifiers' started by eskimo.ganges, Sep 6, 2007.
  1. eskimo.ganges
    eskimo.ganges
    I have Philips HTS3548/98 system - a low end Home-theater system. Now I want to upgrade the setup with a good Amp. My shortlisted Amps are
    Denon AVR-687 7.1-Channel ,Onkyo TX-SR605 7.1 and Yahama DXZ
    Im not sure if the my present philips speakers are compatible with these AMPs , nor can I find a way to check it out. Can someone help me out to check this.
    thanx in advance
    raj
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,474
    2
    +1,366
    Just looked at the instructions and to be honest you would be better selling the system off.
    Reasons
    3 ohm speakers (too low)
    Non powered sub (not suitable)
    And the main one I doubt if the speakers could even cope with power output of a new AV amp.
    This and for many other reasons is why all-in-one systems are a pain. If you need to change one bit then it is all of it.
    Manual http://www.p4c.philips.com/files/h/hts3548_98/hts3548_98_dfu_eng.pdf
  3. eskimo.ganges
    eskimo.ganges
    20 ohms speakers goes with (almost all) Amps rite?. I got budget of around 400$ any suggetions ... looking for good amp + atleast 1 active woofer. + 2 (or 4) speakers .
    got hold of denon set ( amp + speakers 7.1 gizmo ) cost 405$ on amazon.com.
    But im not sure about the speakers of denon.
    any suggestions in this regards ????
    thanx
