Have used a Philips HDT8520 without many issues for the last 18 months. However recently moved country out of UK. Understandably the box cannot tune into signal in our new location but we have still been able to view the (many!) recordings in the library.
Unfortunately today we did a factory reset - have done this in the past and knew that the library was still saved - but this time we are stuck in the first installation set up. It looks like because the box cannot find a TV signal here it will not go past the installation and that means we can't get to the library. The display on the box says 'first install' and on screen it is suggesting that we check signal strength and won't go forward from there.
Does anyone know if there is a way to get the box to accept it won't find a signal and just allow us to access the hard disk library?
