Philips HDD100 - HELP
Discussion in 'Headphones, Earphones & Portable Music' started by noodlesalad, Jul 13, 2005.
  1. noodlesalad
    noodlesalad
    Hi.. i was wondering if anyone knows ANYTHING about this product.. ie. quality, sound, battery life, etc.
    AND .. is there an FM transmitter that is compatible with this mp3 player?
    AND .. can someone recommend an fm transmitter brand that is good? thanks.
  2. kamp
    kamp
    I dont know much about the unit, but quick search on google says the battery runs for 10 hours.
    As far as FM transmitter goes, it doesn't matter which one you use as long as you have a headphone jack on the unit (which I am pretty sure there is).
    All it does is transfer the music into FM signal.
