philips fw-c399
Discussion in 'Hi-Fi Stereo Systems & Separates' started by eggy, Sep 3, 2005.
  1. eggy
    eggy
    i had this mini hi fi packed away in a box for 2 years until 2 weeks ago never been used i did the pre use installation which went ok the radio worked great i then placed 3 cd s in the tray & got the message 'disk not initialized' for all 3 disks. strange error as the 3 disks are pre recorded from music store with relevant artist they all work in a £20 portable cd player has anybody any ideas if laser is dead & if so cost how & to fit etc. i didn't buy a extended warranty as i thought iam not going to use it for a while so why purchase one. i have tried many cd s all do the same thing.
    thanks if you can help in advance
    i am in the uk
