Philips Freeview
Discussion in 'Freeview & YouView' started by rimshot, Nov 15, 2003.
  1. rimshot
    rimshot
    Hi Guys,
    Is this a bargain? Philips freeview box at Boots.com 49.99 if you spend 50.00. My wife say's no problem!
    Roger
  2. Pod Person
    Pod Person
    It lacks 7 day epg but it has all the connections you are ever likely to need on a stb. But no rf re-modulator though.
    So if you are not bothered about 7 day epg then go for it. :smashin:
  3. dealmaker
    dealmaker
    Feb 21, 2001
    740
    nearly in Scotland!
    Sounds like a good deal BUT is the Philips remote codeable like the Pioneer and Sony i.e. can you input a code to make it work with other band TV's???
    Many thanks
  4. nwgarratt
    nwgarratt
    May 5, 2002
    26,405
    +2,859
    I had to return mine as it kept freeezing on ITV and Channel 4. Oher boxes were fine.
