Philips DVR75 wont play "Italian Job"
Discussion in 'Blu-ray & DVD Players & Recorders' started by C.Wolf, Jul 7, 2004.
  1. C.Wolf
    C.Wolf
    Mar 6, 2004
    392
    28
    Kent
    +26
    Recently my philips DVDR880 was exchanged under warranty for a DVDR75. This machine seemed much better and much more reliable until yesterday, when it failed to recognise the 1960,s version of the Italian Job. It got as far as selecting english, then displayed "Disc Error!". I tried several times, but no luck. I then tested the disc in my sons playstation 2 and it worked ok. In my friends DVDR70 it would not recognise again. The disc is in mint condition, and used to play ok on my old samsung 511, and on the old philips DVDR880. Has anyone else had problems with this machine not playing certain films?
    Regards,
    Clyde.
  2. C.Wolf
    C.Wolf
    Mar 6, 2004
    392
    28
    Kent
    +26
    Well if nobody else has had any problems then I guess im going to have to phone those unhelpful people at philips customer services, as it would appear that the machine must be faulty. :rolleyes:
  3. trent24
    trent24
    Just tested it on mine and it works fine.
    Trent24
  4. iamthenewno2
    iamthenewno2
    Jan 18, 2004
    44
    11
    +5
    The Italian Job is the only DVD I (as yet) can't play in my DVDR75. It crashes at the pick language screen strangely I have other disks with the same screen and these work fine. I would be worried but this is the only disk and I have another player.
  5. trent24
    trent24
    How come it works fine on mine then?!?!?! I have the region free model from Richer Sounds with the latest firmware. Strange.
  6. C.Wolf
    C.Wolf
    Mar 6, 2004
    392
    28
    Kent
    +26
    Mine is also the multireigon version, but it crashes just after selecting english. This is also the only disc in mine to do this so far. What is the number of your firmware version trent24, so I can compare to see if maybe its a firmware issue.
  7. Damian1978
    Damian1978
    Jul 15, 2000
    4,513
    107
    Fleetwood, Lancashire
    +261
    I've tried two Region 2 made to Multiregion DVDR70's and neither of them will play the Italian Job either! :confused:
  8. phelings
    phelings
    Jul 24, 2003
    1,025
    36
    A magazine did print a reply from Philips who admitted this fault was known,but they could offer no way round it.
    Let us know what Richer Sounds have to say.Take the disc with you and when they see it play ok on their other players they won't be able to say the disc is faulty.If you can get another exchange,forget Philips,they are more trouble than they're worth.
  9. C.Wolf
    C.Wolf
    Mar 6, 2004
    392
    28
    Kent
    +26
    Trent24,
    What software version are you using? Your machine seems to be the only one here that will play this disc, and we're told that even philips admit there is a problem with this disc. My machine is no more than 3 months old, could your firmware be newer than this?
    Regards,
    Clyde
  10. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    The latest firmware is FF16k and was only released on 1/7/04
  11. C.Wolf
    C.Wolf
    Mar 6, 2004
    392
    28
    Kent
    +26
    Thanks JefUK, do you know if this solves the "italian job" fault. Also will loading on new firmware delete the multireigon hack done by the shop I bought the machine from?
  12. JefUK
    JefUK
    Mar 31, 2002
    448
    28
    +54
    No, I'm afraid I don't know whether it solves the problem, but the implication of trent24's reply is that it does.
    I have a multi-region DVDR80, and that remains multi-region after upgrading the firmware, can't say for sure about R70 but I would assume that it would also be OK.
  13. C.Wolf
    C.Wolf
    Mar 6, 2004
    392
    28
    Kent
    +26
    Just checked my firmware, its FF13k. Think I better start looking into how to change it to FF16k. Cheers JefUK
  14. iamthenewno2
    iamthenewno2
    Jan 18, 2004
    44
    11
    +5
    For your info...
    FF16K does not fix the Italian Job error, I have just updated the recorder and no luck. Oddly for second it showed M8 as recording mode but now I can't find it again, strange.
  15. C.Wolf
    C.Wolf
    Mar 6, 2004
    392
    28
    Kent
    +26
    Cheers No2, if this doesnt fix the fault then I dont think ill upgrade, just incase it introduces any other bad side effects (see how much confidence I have in philips!).
