Philips DVP620
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Icecasque, Dec 14, 2004.
  1. Icecasque
    Icecasque
    Philips DVP620
    Open tray and leave it open
    press 7 8 9 "ok" 0 on your remotecontrol
    There should be a "zero" on the lefthand of the screen
    The last digit is the region.
  2. bw57609
    bw57609
    I have a Philips DVP620DR/05 and this hack does not work
    Anybody got a working region free hack for this player??
  3. Sick Note
    Sick Note
    Nov 8, 2000
    451
    +26
    Hey mate try here.
    Hope it helps
  4. Justin@UH
    [email protected]
    Feb 21, 2002
    2,192
    63
    Location location location
    +93
    Try the "standard" DVP hack, works on just about all Philips DVP series...
    Press "System Menu" key to enter Set Up menu.
    Move to "Preference Page" using arrow keys to the left or to the right.
    Press the following sequence in the remote control: 135566
    A menu indicating "Region Code" will appear.
    Change region using arrow keys to top or down.
    Region Code = 0 will play all regions.
    Press "System Menu" key to exit Set Up menu
    Worth a try:)
  5. bw57609
    bw57609
    Cheers Sicknote, but I have already seen that
    Going to try Justin's instructions when I get home from work. Cheers guys
  6. bw57609
    bw57609
    Thanks Justin but it didn't work
  7. bw57609
    bw57609
    I don't have a preferences page
    All I have is a page with 3 option quick setup, custom setup or initialize
    Quick setup - player menu language, tv aspect, dolby digital, mpeg
    Custom setup - Language, display, audio changes and parental lock with a few selections under each sub heading
  8. hstaveley
    hstaveley
    does anyone have a hack that works yet???
  9. nicolagoodanew
    nicolagoodanew
    :lease: hi - This does not work on mine. Has anyone got it working?
    When I have the drawer open, and input the numbers, I am just met with the blue screen - nothing happens.
