Philips DVP520 menu oddity
Discussion in 'Blu-ray & DVD Players & Recorders' started by Wobbler, May 17, 2005.
  1. Wobbler
    Wobbler
    May 17, 2005
    10
    Got one of these a little while ago on special offer from Amazon, excellent little player that plays discs that my other players won't even recognise as being loaded.
    Getting a weird fault every now and again with the menu in DVDs where you select chapters etc - all the indicators against the choices disappear so you can't see what you are selecting.
    The choices still work if you guess where you are and press OK but obviously it's not right.
    The only way to cure it is to power off at the mains, wait a few secs until the power indicator has gone out and then plug it in again.
    Maybe there is some corruption in the firmware, anyone know if firmware for this player can be downloaded from anywhere and applied?
  2. ken10
    ken10
    Dec 28, 2005
    4
    I have just encountered the same difficulty. I'll try the power off band aid you mentioned, but did you ever get any final solution?
    Thanks in Advance.
    Ken
