Philips DVP 5960 usb
Discussion in 'Blu-ray & DVD Players & Recorders' started by Moondust, Sep 10, 2007.
  1. Moondust
    Moondust
    Sep 9, 2007
    5
    Hi, could anyone tell me if the philips dvp5960 supports divx film playback via the usb?? Having tried it my picture just becomes very pixelated. Thanks for any help...:)
  2. Paul97
    Paul97
    Jan 20, 2004
    655
    Hartlepool
    +24
    Hi Moondust
    I have the 5980 & have no problems with using USB drive, not sure about your problem could it be your USB stick:confused:
    Paul
  3. Matt_C
    Matt_C
    Aug 14, 2005
    9,870
    Essex
    +1,847
  4. Bendolfc
    Bendolfc
    May 10, 2007
    115
    +15
    Works fine with USB HDD's
  5. Moondust
    Moondust
    Sep 9, 2007
    5
  6. Bendolfc
    Bendolfc
    May 10, 2007
    115
    +15
  7. Haggler
    Haggler
    Sep 11, 2007
    4,960
    Workbench bootblock
    +662
    Having had this player since the beginning of the year i can confirm that mine played divx files perfectly from the usb, either from portable hd or usb stick.
    I did read somewhere that the manufacturer of the usb stick could make a huge difference and also you may need to make sure it's formatted to fat32.
    My player also supported packed bitstream straight out of the box, should be no need for a firmware upgrade or to use mp4 modifier to fix this particular problem.
    This is a great player for less than £50, i only upgraded due to buying a new tv and wanting a home cinema system.
  8. Bendolfc
    Bendolfc
    May 10, 2007
    115
    +15
    Mine didn't and I only got it a week ago, was running the latest firmware too (12.06.36.40). Packed bitstreams were jerky when the camera panned, using a 3rd party firmware it's smooth.
  9. ukdoctor
    ukdoctor
    Jul 16, 2007
    41
    +4
    i watch all my films on the 5980 thru the USB
