Philips DVDr880 Disc Error
Discussion in 'Blu-ray & DVD Players & Recorders' started by AkhilStyle, Apr 13, 2005.
  1. AkhilStyle
    AkhilStyle
    Jul 24, 2004
    32
    Hello
    I just got this off someone. I managed to record something. Then I tried something else and it says "disc error" and does not record. I have tried TDK and Philips DVD+RW but they both say that.
    Any ideas guys? What should I do. I have contacted the person I brought it off.
  2. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Unfortunately there's no doubt that it's broken and needs repairing by Philips themselves. The 8x0 series are notorious for this malfunction, which is due to a misaligned laser OPU.
    If you can get the original proof of purchase you might be able to get it done free of charge. Otherwise get your money back immediately.
  3. Marfun
    Marfun
    I am so sorry for you i know this might sound daft but i have had three of these machine and the same thing has happened on every single one of them and it is so off putting and is enough to put anyone recording dvd disks at all
    I have still not found a sure proof way of fixing the discs that i have recorded using the phillips 880 but it seems to be a problem most of the time with the finaliseing and the laser picking up the starts fo titles on the discs.
    I would never recommend any phillips dvd recorder to anyone as they all have this wierd problem
  4. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Do you have proof of purchase for each of them? Credit card statements will be fine, if not the bill of sale...
  5. AkhilStyle
    AkhilStyle
    Jul 24, 2004
    32
    I brought it off someone :S
    I don't think they do :S
    I have emailed philips with serial number etc and will see what they say. I have also emailed the person I brought it from - I brought it off them brand new - so should be under warranty
    Akhil
  6. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
  7. Debs67
    Debs67
    I've got the 890 and the same happened to me,it also wouldn't read Pre-recorded DVD's sometimes!! :eek:
    I had it fixed under my guarentee luckily,now it's great. :smashin:
    But many people with the 8X0 line have this problem...many! :mad:
    Debs
  8. AkhilStyle
    AkhilStyle
    Jul 24, 2004
    32
    Thanks for the help guys
    I just tried recording something with the SAME discs and it has been recording for 15 mins fine now - it usually gets the error after about 20 secs. Hopefully it will stay ok
    My new discs are coming today also
  9. AkhilStyle
    AkhilStyle
    Jul 24, 2004
    32
    Thanks for that number
    New discs didnt seem to work - however it was not a disc error, it just frroze about 2-4 secs after I press record and then restarted.
    I called that number you posted earlier - very helpful, I explained that I got it off ebay. They asked me to get the date of purchase - which I am trying to get hold of now - and explained they had a 2 year warranty - so hopefully it will be under warranty and then I can arrange for a repair
