Philips dvdr75
lazysod
Established Member
Joined
Jun 17, 2002
Messages
489
Reaction score
15
Points
93
Age
64
Location
Leeds,Kent
Hi ,does anyone know why the recorded video from the dvdr75 plays back in 16:9 on the Philips but only plays back in 4:3 on any other DVD player, even after putting it through TMPGenc DVDAuthor.
Just read a few posts on the subject ,looks like it,s the w/screen flag. What a flaw in this day of widescreen tv,s.
Yes in VR mode,its just that the dvd guidelines dont support this so DVD players play it back in 4:3 so you have to use zoom mode
so if i record from my sky box which is widescreen to my dvdr-75 then it should playback in widscreen formaton the dvdr 75..i think??
am i correct
um there must be something wrong with mine then as it dont play back in widescreen mode...?? would rgb have anything to do with it as i record from rgb but can only out put normal scart as i only got one rgb scart on my widescreen tv..
rob
Wouldnt have thought RGB would make any difference, you have got it set to 16:9 in the menu i take it. I dont use RGB my self as I connect everythig through my receiver,s S-Video
yeah a little confusing i will have to play around i find that if i look at my sky picture directly linked to the tv it all looks fine, but when i look at the same picture travelling through the recorder the picture is squeezed up a little and does not look fully widescreen...i dont know why and also why it has only started happening or i didn't notice it before hand??
thanks for your help
rob
Sony BRAVIA 9 Mini LED TV: The Best HDR TV EVER?
Back
