philips dvdr70 sound synch problems
S
soswin
I've been getting sound synch problems when playing some DVDs / VCDs on my philips dvdr70. Had to switch to my PS2 for playing Dog Soldiers. Strange thing is it doesnt seem to effect programs I've recorded. Any one else experienced this? Its only a week old so I'll probably take it back.
Tetlee
How much did you pay for your DVDR70? I bought my DVDR75 from Richer Sounds a month ago, multi-region for £240. If you payed more I'd take it back and get the DVDR75 instead, has the i-link added;) .
Oh, and I've been well impressed with my Philips DVDR75 so far:clap: , no problems with sound synch here!!
R
robpiggott
tet
have you updated the firmware and how can you tell when philips release new firmware.
rob
S
soswin
Paid £278 from John Lewis, 2 year warranty though. I put the latest firmware on a few days ago, not sure if theres another update out yet. Seems great at recording ( I like the sat feature so it records what you autoview on sky ) just the odd DVD plays back with the synch problem.
Tetlee
Originally posted by robpiggott
tet
To be honest I didn't even know it was possible to update the firmware so I can't hepl you there. So far I haven't had any troubles so have'nt had the need for updates, but if you find out please let me know just incase:)
By the way Soswin, Richer Sounds do offer an extended warrenty of 3 years for an additional £30 (if I remeber that right). If you don't use the warrenty after that time then they will refund you the £30:smoke: . So still worth considering if you have a Richer in your area I would think. Personaly I didn't bother with the extended warrenty as I never do (would probably forget to reclaim the £30:laugh: )
R
robpiggott
updated the firmware in mine using the download from philips support. all went fine and to be honest i didn't use the recorder before this so i dont know if there are any improvements or not. also got mine form richer sounds but with the 3 year warranty bearing in mind the negative reviews on philips dvd recorder in the past after six months use...only time will tell and if i dont use it then i can get me £30 back!!
rob
BKATZ
Interesting,
I have had the same problem with a few discs, & thought it was the disc!
(I have done the firmware upgrade)
Anyone got any other ideas?
B.
S
soswin
I got a replacement from john lewis, the new one doesnt have the same problem. Interestingly this one came with the latest firmware where as the last one needed upgrading.
S
soswin
Now the replacement is having problems, this time with "wrong turn". Piece of cr*p. I know its not the disks as they play ok on my PS2. I'm going to get a refund, get a sony or panasonic instead.
S
soswin
Been using a panasonic E50 for about a week now, I prefer it to the philips. Playback of DVD's is better, so far no synch problems. Recording quality seems the same, the philips would be good if they could just sort out these faults.
🎬 The Top 20 Most Anticipated Movies of 2024
Back
