philips dvdr70 hack
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by stan kerss, Dec 15, 2004.
  1. stan kerss
    stan kerss
    hi i'm wondering if anyone can help me?
    i'm after a hack for a philips dvdr70 to make it region free iwould be most grateful
    many thanks
  2. Tafsir
    Tafsir
    Jul 9, 2002
    1,209
    48
    uk
    +97
    1)Via the "System" button on your Philips remote, on your recorder (no disk in recorder), change the "Remote control used" from "DVD Recorder" to "DVD Player". Store it. (This is IMPORTANT!)
    : 2)On your Philips remote press Play 159
    The display on the recorder should now change to eleven dashes.
    : 3) Still using your PHILIPS remote, tap in 121 212 005 255 (the last few digits will NOT be visible on screen but they WILL be there). Now press "Play" on your PHILIPS remote.
    : 4)Power down your recorder, wait a few seconds and Voila!!. You now have a region-free beastie!!
    : 5)..Via the "System" button on your Philips remote, on your recorder (no disk in recorder), change the "Remote control used" from "DVD Player" to "DVD Recorder". Store it.
  3. stan kerss
    stan kerss
    thanks for the info but sadly it did'nt work
    thanks again
  4. Tafsir
    Tafsir
    Jul 9, 2002
    1,209
    48
    uk
    +97
    try this 1 m8
    : 3) Still using your PHILIPS remote, tap in 121 212 005 001 (the last few digits will NOT be visible on screen but they WILL be there). Now press "Play" on your PHILIPS remote.
  5. Deggsy
    Deggsy
    Dec 30, 2004
    14
    I just got the Philips DVDR70 in a present and have tried the region-free hack that is quoted everywhere (even on Amazon) but it will not work. I've followed the instructions to the letter. Any ideas?
  6. david park
    david park
    :confused:
    Well both numbers in step 3 make my DVDR70 play region 1 discs now, BUT it will not play UK discs now.
    I NEED HELP, Tafsir, or anyone quick please.
    What number makes it Multi Region, or at least back to Region 2 (UK)?
  7. Tafsir
    Tafsir
    Jul 9, 2002
    1,209
    48
    uk
    +97
    Try This M8
    121212005255 ( Multi)
    121 212 005 002 ( To Turn It Back To Region 2)
  8. Deggsy
    Deggsy
    Dec 30, 2004
    14
    Hi Tafsir
    Neither set of numbers works for mine. Any suggestions? Return it to Amazon?
  9. Tafsir
    Tafsir
    Jul 9, 2002
    1,209
    48
    uk
    +97
    i dont now what is happening guys as i got my player when it first came out & used this hack
    enless there have changed the firmware or something in the new models of the same player
  10. Tafsir
    Tafsir
    Jul 9, 2002
    1,209
    48
    uk
    +97
    what ever you do guys dont keep trying the hacks , if it works , great,
    but i have read somewhere if you pressing play 159 after so many trys it will lock, and the player will by no good to you, or you want be able to try the hacks nomore
  11. david park
    david park
    The first number gives Region 1 not multi.
    The second gives it back to region 2
    Are you the only person to get it to work Tafsir?
    Can you refer us to the web site you got it from?
    For other makes useually one ends up inputting a 1 for region 1 and 2 region 2 and 3 for region 3 etc.
    Ending up with 0 for multi region, should your number end with a 0?
  12. Tafsir
    Tafsir
    Jul 9, 2002
    1,209
    48
    uk
    +97
  13. Deggsy
    Deggsy
    Dec 30, 2004
    14
    After you change from DVD Recorder to DVD Player in step 1, do you enter the Play 1,5,9 within the System menu, or do you exist from there first?
  14. Deggsy
    Deggsy
    Dec 30, 2004
    14
    Hi Tafsir or anyone else who can help
    Amazon replaced my Philips DVDR70 and I have followed their, and your instructions to the letter. I can get it to play Region 1 by using 001 at the end of the code but the player will not accept 255 as multi. Any suggestions or should I just return again and get a better machine?
  15. aahannes
    aahannes
    Thanks to Tafsir,
    the hack for the dvdr70 worked also perfectly for my dvdr75 model !!
  16. colinw
    colinw
    Jan 16, 2005
    444
    +17
    my neighbor has a dvdr70 and i can't multiregion his unit either ?
    using the philips remote method did'nt work, and using the kamelian one for all remote with the magic 085 did'nt work as well !!
    tried both methods exactly as per instructions, no joy at all.
    wierd thing is i can't get the dashes up on the display using the magic 085 method, even though the unit is in player mode and the one for all remote works fine with it, ie on/off, channel change etc.
    i even done a firmware update in the end but still no joy !!!
    whats annoying me is a long time ago i done a 980 and dvdr70 using the magic 085 method and they worked fine, but i think at the time i also could'nt get the dashes up on the display, but then i done something and up they came, and i can't remember what i done.
    damm fustrating !!
