Philips DVDR630RW
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by id001, Mar 1, 2005.
  1. id001
    id001
    I have a Philips DVDR630VR, trying to make multi-region using the URC7544 All For One remote.
    If I try the recommended hack, using code 0539 to control the machine nothing happens - it doesn't accept the code.
    The only code I can get it to accept is 0646, but when I then try the Magic - 085 nothing happens, i.e. no dashes onscreen.
    I read that you're supposed to set the remote control to DVD Player rather than DVD Recorder, but there's no option to do that (it should be in the System menu, right?). I'm guessing that's what my problem is.
    Any advice on this would be appreciated.
    Thanks in advance
  2. id001
    id001
    Anyone?
    Or anywhere I can look? I've read through all of the documentation available and can't find how to change the default IR device to Player (it's certainly not on the System Menu)
