Philips DVDR520H cannot copy from HD to DVD
Discussion in 'Blu-ray & DVD Players & Recorders' started by jwellings, Aug 7, 2005.
  1. jwellings
    jwellings
    I've copied a home-produced VHS tape onto my hard drive.
    Now I'm trying to make a copy of that recording onto a brand new DVD+R disc.
    I keep getting the error message
    "The function you specified is not supported due to some limitations. Please split the title and try again."
    At first I though it was because the length of the recording was in excess of the DVD disc space but I've checked the record speed I selected and that's OK.
    I then tried copying a recording I'd made off the Tv from HD to DVD and that worked fine.
    Any ideas why this is happening?
    [ADDED]
    Just noticed I recorded the VHS tape as M1 quality, the recording lasts 1h:37m which means M1 would be too big for the DVD. Maybe if I re-record it as M2 or M2X that will fix the problem.
