Philips DVDR3380 vs Samsung DVDR135
hotchilidamo
I've narrowed my choice down to these two and I was hoping someone on here had one of them and could recommend or put me off to help me choose.
Any suggestions between the Philips DVDR3380 or the Samsung DVDR135 ?
T
thederson
Hi, I've just got the Phillips (managed eventually to exchange my faulty Technika DVDR-2005 at Tescos).
The software (menus, etc) look exactly the same as the Technika, however the machine build is far superior. It doesn't feel like the thing is going to fall apart when you hit the eject button.
Plays all the divx files you can throw at it and it will record to both + and - discs apparently (the Technika would only record to + I believe)
Hope that helps a little
