P
Pip_UK
If you record a DVD via an RGB input (digital cable box), are you restricted to RGB video output when playing back the DVD?
The reason I ask is I only have the option of displaying component and s-video signals.
If I need to get an S-video convertor ... would it make any difference where it was in the setup? ie before DVDR1000 input signal or after output signal, in otherwords recording in RGB or S-video
This has been puzzling me for ages ...
Anyone know the answer?
Cheers,
Pip
Cheers,
Pip
