Philips DVDR-70
Discussion in 'Blu-ray & DVD Players & Recorders' started by efitchuk, Jul 22, 2004.
  1. efitchuk
    efitchuk
    I have recently purchased the DVD recorder above, and have two small problems. The first one is that I cannot make it multi-region, despite trying different hacks. The second, which could be a consequence of the first but may not be, but some of my Region 2 DVDs will not play and come up with the message that the region of the disc is not the same as the player. Can anyone help?
  2. SystemBlack
    SystemBlack
    I don't think you can make it "multi-region", I have a DVR 75 and it does say in the manual that it's region 2 or region ALL. This means it will play discs which have Region2 on the disc or Region ALL. This is different than saying it's multi-region, ie plays Region1, Region2, Region3 etc.
    If anyone can tell me how to make it "multi-region" I would like to know.
  3. SystemBlack
    SystemBlack
    ps: try downloading the latest firmware to fix the problem.
