Philips DVDR 70 MP3 problem
Discussion in 'Blu-ray & DVD Players & Recorders' started by kodge, Mar 8, 2005.
  1. kodge
    kodge
    Mar 8, 2005
    3
    Hi everyone out there.
    My Philips DVDR70 will not play MP3s. Discs recorded using Toast 6 Plat. from my iMac. Has anyone else come across this?
  2. Niburu
    Niburu
    My Philips DVD recorder has no problems reading MP3 files and neither should your DVDR70.
    Check and make sure you have met the criteria set out in your machines manual for creating MP3 discs.
  3. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Unless you have the ".mp3" file extension added, your DVDR will not recognise the files. IIRC Toast doesn't do this by default.
  4. kodge
    kodge
    Mar 8, 2005
    3
    Thanks, Niburu, I'll check again.
  5. kodge
    kodge
    Mar 8, 2005
    3
    Thanks, Musukebba. This may put me right.
