Philips DVDR-610 recorder
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jedwards, Feb 1, 2005.
  1. Jedwards
    Jedwards
    Jan 31, 2005
    44
    I have just purchased a DVDR-610 recorder but am unable to connect it up properly to my amplifier (Sony HTK-215) due to the fact that it only has a coaxial output, & the amplifier only has an optical input. Does anyone know whether I can get round this by buying a Coaxial to Optical converter?
    Will I be able to get 5.1/DTS sound?
    Thanks!!
  2. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    Your best option is to connect to phono outs on your TV - then you can amplify whatever it is you're watching
  3. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    His best bet is to return the Philips 610 and replace it with something more suitable to his needs - the Pioneer 220 for example offers coaxial digital output. I would humbly suggest that this is a somewhat better solution than abandoning 5.1 sound!
    If the original poster does an internet/forum search for Philips DVD recorders he might well see this is good advice. So far every generation of Philips DVD recorders has been plagued by problems - many proving to be criticial. Whilst the likes of Jethro will say "it was on older models" the same disc error, display lockups and refusal to play commercal DVDs come up time and time again. And this is before you even consider the fact that Philips machines are 'lite' on performance and features. :thumbsdow
  4. Benfica
    Benfica
    Maybe I'm wrong, but i think pioneer recorders only have 1 optical digital output and none coaxial digital output.
    However, there are coaxial <-> optical digital converters that you can use.
    Hope that helps
  5. Rasczak
    Rasczak
    Apr 3, 2002
    21,240
    Warwick
    +2,282
    No you're quite right - my mistake (could have sworn I had connected at least one of my Pioneer models by coaxial - my memory must be going!) - look at something like the Toshiba DR3 instead.
    Optical to Coaxial converters mentioned can be found here - but do note that using such devices is not always trouble free.
